Testing an RS232 Printer
Tthe RS232 Print screen lets you test connectivity and print line-by-line at a serial printer.
- Connect the RS232 cable from the printer to a workstation COM port.
- Select the COM port from the Output Port drop-down list.
- Press Test Ports.
- Verify that the Tx Bytes field and the Rx Bytes field increments and that the printer continues printing.
- Press Quit Test.
