Calibrating the Workstation and 10-Inch Customer Display
Follow
the steps below to calibrate the workstation and 10-Inch Customer
Display:
Microsoft Windows 10
- Connect the 10-Inch Customer Display to a Workstation 6 Series workstation.
- Connect a mouse to the workstation.
- Right-click the desktop, and then select Display settings from the popup menu.
- Click Extend These Displays, and then click Keep These Changes.
- Open the Control Panel, and then click Tablet PC Settings.
- In the Display Options box, verify that “1. Mobile PC Display” appears in the drop-down list.
- In the Configure box, click Setup, and then touch the workstation screen when “Touch this screen to identify it as the touchscreen” appears.
- Click OK to exit Tablet PC Settings.
- Double-click Intel HD Graphics Control Panel, and then select Display.
- Verify Select Display is set to Built-in Display.
- From the Resolution drop-down list, select 1920 x 1080, click Apply, and then click Yes to continue.
- Right-click the taskbar, and then click Properties. In the Multiple Displays area, click to turn off Show taskbar on all displays to disable the taskbar on the 10-Inch Customer Display.
