Install and Configure an Epson Serial Printer That Prints to IDN COM 4
Power off the workstation.
Connect the 9-Pin male end of the IDN to RS232 cable assembly to the 9-pin female connector on the printer or cable attached to the printer.
Insert the RJ-45 connector end of the cable assembly into the IDN COM 4 port on the Workstation 625/655.
Power on the workstation and then immediately press the right or left bottom of the display until a beep sounds to enter the BIOS.
Select Workstation, and then scroll down to make the following changes:
422 Mode Selection = Disable
232 Mode Selection = 232 Mode
Press Home menu (bottom of display) then Save & Exit.
Select Exit Saving Changes, and then save configuration changes and exit now.
The workstation will boot into Windows 10.
