Peripheral Expansion Module Stand Mounting Points
Figure 3-2 Peripheral Expansion Module Stand Mounting Points
Table 3-2 Peripheral Expansion Module Stand Mounting Points
Mounting Point | Description |
1. Captive screw |
The captive screw secures the Peripheral Expansion Module to Workstation 8 Series stands. Use the Oracle 2.5mm hex key to tighten. |
2. Stand mounting edge |
The stand mounting edge slides into the mounting slot on Workstation 8 Series stands. |
