1 Preface
Audience
This document is intended for those who set up, install, and operate Oracle Workstation 8 Series workstations. It is not specific to a particular software application.
Admonitions
Unless specified, the information in this document applies to each configuration of the Workstation 8 Series.
The following symbols may appear in this document:
This figure shows a yellow triangle containing an exclamation point.
Caution: There is a risk of personal injury and equipment damage. Follow the instructions.
This figure shows a yellow triangle containing wavy vertical lines (hot surface symbol).
Caution: Hot surface. Avoid contact. Surfaces are hot and may cause personal injury if touched.
This figure shows a yellow triangle containing a zigzag downward arrow (high voltage symbol).
Caution: Hazardous voltages are present. To reduce the risk of electric shock and danger to personal health, follow the instructions.
Customer Support
To contact Oracle Customer Support, access My Oracle Support at the following URL: https://support.oracle.com.
When contacting Customer Support, please provide the following:
  • Product version and program/module name
  • Functional and technical description of the problem (include business impact)
  • Detailed step-by-step instructions to recreate
  • Exact error message received
  • Screenshots of each step you take
Documentation
Oracle Food and Beverage product documentation is available on the Oracle Help Center at http://docs.oracle.com/en/industries/food-beverage/.
Revision History
Date Description of Change
June 2023
  • Initial publication.
June 2023
  • Added additional information.
May 2024
  • Added Modular MSR installation steps.
December 2024
  • Updated product specs table.
March 2025
  • Added USB fingerprint reader installation steps.
March 2026
  • Updated compatible operating systems.
