Care and Handling
Equipment Placement
Keep the Workstation 8 Series within an operating temperature between 0C (32F) and 50C (122F).
If you are placing your equipment in an area adjacent to carpeting, use an anti-static grade of carpeting. If you do not have anti-static carpeting, use static discharge mats.
Do not place equipment near food preparation areas, glass racks, or water stations. Although the Workstation 8 Series is highly spill resistant, take care to avoid using electrical equipment near water.
Take precautions to prevent the accidental dropping of metallic objects such as paper clips and staples into the equipment.
Electromagnetic Interference
Do not run exposed cables in the vicinity of AC power lines because the noise radiating from the AC power lines can be absorbed by Workstation 8 AC power and communication lines.
Keep devices that emit RF energy, such as cordless phones, at least eight inches from the equipment or cable during operation.
Cleaning the Workstation 8
Use only a soft, lint-free cloth. Avoid abrasive cloths, towels, paper towels, or similar items.
Avoid excessive wiping, which might cause damage.
Don't get moisture into any openings.
Don't spray cleaners directly onto the item.
