Basic Troubleshooting
The following table contains descriptions and solutions for common problems encountered when installing or operating the Workstation 820.
Table 12-1 Basic Troubleshooting
| Problem | Possible Causes | Solution |
The workstation does not start and does not show the splash screen. |
No power to the workstation. |
For configurations without the Peripheral Expansion Module:
For configurations with the Peripheral
Expansion Module:
For all configurations: Verify your country-specific C5 power cord is fully inserted into the Workstation 8 Series power supply. |
The workstation does not start. The operator LCD remains blank after 30 seconds. |
The system board may be defective. |
Contact your Oracle MICROS representative. |
The workstation does not connect to the Local Area Network. |
The network cable is not connected. The workstation is connected to an inactive or improperly configured LAN port. |
For configurations with the Peripheral Expansion Module:
