Starting the BIOS System Configuration Utility
To configure the BIOS, start the BIOS System Configuration Utility using the following steps:
- With keyboard: Connect a USB keyboard to the Workstation 820 USB (CFD) port (adapter required) or an available USB port on the Peripheral Expansion Module.
- Power on or restart the workstation.
- When the message Press <F2> to enter setup appears at the bottom of the screen, press F2 or tap the lower left or lower right third of the bootup screen to enter the BIOS Configuration Utility.
