View POS Check Processing Status
The POS Check Processing Status page provides information about the current status of POS revenue processing.
Next Scheduled Processing In: Displays the number of minutes remaining until the next scheduled execution.
POS Check scheduler: Indicates whether the POS Check Scheduler is enabled or disabled.
Check processing: Indicates whether POS check processing is enabled or disabled.
New check API import: Indicates whether the import of new POS checks through the API is enabled or disabled.
Dispatcher activity: Displays the current dispatcher activity.
Revenue centers enabled for check sync: Displays the revenue centers enabled for synchronization.
Process POS Checks: Enable or disable POS check processing.
Import New POS Checks: Enable or disable the import of new POS checks.
Run Scheduler Now: Start the job scheduler immediately.
The Details view displays information about the import and processing status of POS checks.
If one or more POS checks cannot be processed, the Processing Issues button becomes active. The number in parentheses indicates the number of processing issues. Select Processing Issues to review the details of the reported issues.
Parent topic: POS Processing
