Edit Areas and Shelves An Areas and Shelves definition can be edited only if it is not being used in an open inventory count. On the Dashboard page, click Areas and Shelves. Select the subsidiary from the Subsidiary Selector drop-down list. In the Action menu, click Edit. Make your changes, and then click the Cancel button to return to the definition list. All actions are automatically saved.
