Preface
Oracle MICROS Simphony is a cloud-based Point-of-Sale (POS) solution that provides business management capabilities using a single tool with vast integration capabilities to property management systems, paperless kitchen display systems, credit card interfaces, and reporting applications.
Purpose
This Configuration and User Guide provides instructions to set up the Kitchen Display System in Simphony release 19.3.X and explains its daily use.
Audience
This document is intended for system administrators of Oracle MICROS Simphony release 19.3 and kitchen staff.
Customer Support
To contact Oracle Customer Support, access My Oracle Support at the following URL:
Product version and program/module name
Functional and technical description of the problem (include business impact)
Detailed step-by-step instructions to re-create
Exact error message received and any associated log files
Screen shots of each step you take
Documentation
Product documentation is available on the Oracle Help Center at https://docs.oracle.com/en/industries/food-beverage/pos.html.
Simphony Digital Learning
The Simphony Learning Subscription provides additional product knowledge through interactive training, guided video tours, and helpful knowledge checks. After exploring the documentation library, use your Oracle Single Sign On to check out the Simphony learning opportunities at Oracle Food & Beverage Learning Subscription.
Revision History
| Date | Description of Change |
September 2021 |
Initial publication. |
January 2022 |
Updated the Configuring the Behavior of Production Counters in the Production Items for KDS chapter. |
February 2022 |
September 2023 |
Update to Preface. |
