Linking Prep Stations
Once a Prep Station is linked, you cannot change its display type or link it to another order device without first removing the connection.
  1. Select the revenue center, click Setup, and then click Order Devices.
  2. Double-click a KDS Prep Station order device record to open it, click the KDS tab, and then scroll down to the Links section.
  3. Click Add, and then select a Prep Station to link from the Linked Order Device drop-down list.
  4. Repeat Step 3 to link another Prep Station.
    You can link up to eight Prep Stations to a single order device.
  5. Click Save.
    To work correctly, the Bump Marked Items option (Devices, Order Devices, KDS, Options) must have duplicate option settings for all KDS devices linked to the same order device.
