Configuring the KDS Toolbar
  1. Select the Enterprise, property, or zone, click Setup, and then click KDS Tool Bars.
  2. Insert a KDS Tool Bar record if it does not exist, and then double-click the record to open it.
  3. (Optional) Enter the Button Height and the Button Width, and then select the Background Color for the toolbar.
    If you do not configure a button height and width, KDS uses the default value of 60 pixels.
  4. To configure the KDS toolbar with Oracle Hospitality default functions, click Create Default.
  5. To configure the KDS toolbar with specific functions:
    1. Click Add, select the Function, enter the Legend for the toolbar button, and then if enabled, enter the Parameter for the selected function.
      The Parameter field only becomes active when the function requires a parameter. For function Remote View Specific, enter the record number of the KDS Display that you want to remotely view in the Parameters field.
    2. (Optional) Select the Background Color for the toolbar button, and then select the Legend Color.
    3. Repeat Steps 5-a and 5-b to add all appropriate KDS toolbar functions. KDS Bump Bar and Toolbar Functions contains a list of all KDS toolbar functions.
  6. To reposition the function buttons on the toolbar, in the column with the number sign (#), click the position number of the function, and then click the up and down arrow buttons to move the position.
  7. Click Save.
