Importing Current Settings to a Kitchen Theme
You can import existing configuration information to a kitchen theme record.
  1. Select the property, click Setup, and then click Kitchen Themes.
  2. In table view, right-click the record to which you want to import the settings, and then select Import Current Settings to Kitchen Theme.
  3. Change the settings as appropriate, and then click Save.
