Preface
Oracle MICROS Simphony is a cloud-based Point-of-Sale (POS) solution that provides business management capabilities using a single tool with vast integration capabilities to property management systems, paperless kitchen display systems, credit card interfaces, and reporting applications.
Purpose
This Simphony Client Deployment Guide provides instructions about how to deploy clients for Simphony.
Audience
This document is intended for system administrators of your Simphony system.
Customer Support
To contact Oracle Customer Support, access My Oracle Support at the following URL:
Product version and program/module name
Functional and technical description of the problem (include business impact)
Detailed step-by-step instructions to re-create
Exact error message received and any associated log files
Screen shots of each step you take
Documentation
Product documentation is available on the Oracle Help Center at https://docs.oracle.com/en/industries/food-beverage/pos.html.
Simphony eLearning
The Simphony Learning Subscription provides additional product knowledge through interactive training, guided video tours, and helpful knowledge checks. After exploring the documentation library, use your Oracle Single Sign On to check out the Simphony learning opportunities at Hospitality Learning Subscriptions.
Revision History
| Date | Description of Change |
September 2021 |
Initial publication. |
September 2021 |
Updated the CAL Packages chapter. |
October 2021 |
Updated the CAL Package Deployment chapter, specifically the Scheduling and Viewing Device Information topic. |
November 2021 |
Updated the CAL on Workstations chapter, specifically the Installing the Simphony Service Host on an Android Device topic. |
March 2022 |
Relocated the Setting Up a New Workstation With a DCAL Server topic from the Troubleshooting CAL and DCAL chapter to the Distributed CAL (DCAL) chapter. |
September 2022 |
Updated the CAL on Workstations chapter, specifically the CAL Installation Prerequisites for Microsoft Windows Devices topic. |
March 2023 |
Added the Android Device Workstations chapter. |
October 2023 |
Updated Configuring an Android Workstation in the Android Device Workstations chapter. |
