CAL Installation Prerequisites for Microsoft Windows Devices
Add the Microsoft Windows workstations to the EMC prior to installing the point-of-sales (POS) client software, ServiceHost, etc. Once the workstations are configured, assign the default sign in and transaction pages.
Ensure that the EMC server and the Microsoft Windows device are on the same time zone.
Ensure that you can access
https://[EMC Server IP]:443/egateway/egateway.asmxfrom the EMC server machine and from the Microsoft Windows device. You cannot use an IP address when CAL obtains the files from the Enterprise only. The domain name works as it requires a valid certificate. Currently, Simphony Enterprise CAL deployment no longer uses IP addresses, rather the Simphony URL must be a fully qualified domain name (FQDN). Simphony DCAL CAL deployment can still use the IP address of the DCAL server workstation. -
Assign the employee privilege to download software, install and authenticate clients and Service Hosts using CAL.
Users must have the employee privilege assigned to the appropriate role to successfully authenticate Microsoft Windows devices, Android devices, and Kitchen Display Systems (KDS). EMC users do not automatically acquire this privilege during an upgrade to release 2.9.1 or later. After installing or upgrading to Simphony release 2.9.1 or later, you must assign the privilege to a user’s role. When the Role option is set, employees can use their EMC logon credentials when CAL’ing devices. Allowing Employees to Install and Authenticate POS Clients and Service Hosts contains more information on assigning the privilege.
Set the CAL deployment schedule. Configuring the Deployment Schedule to Install CAL on Workstations contains information on deploying CAL packages.
Parent topic: CAL on Workstations
