Configuring the Deployment Schedule to Install CAL on a Workstation Without the POS Interface
  1. Select the Enterprise, click Setup, and then click CAL Packages.
  2. Select Service Host Prereqs from the left pane for all POS clients.
  3. Click the Deployment Schedule tab, and then click Add Deployment.
  4. From the Deployment Type column, select 2 - Specific Service Host.
  5. In the Service Host column, click the ellipsis (...) point button, select the CAPS workstation, and then click OK.
  6. In the Action To Take column, select 0 - Install, and then click Save.
  7. Select Service Host from the left pane, and then repeat Steps 4 through 7.
