CAL Authentication with DCAL Workstations
Fresh Simphony Client 2.9.1 or later installations, which are deployed through DCAL, display a ‘Not Authenticated’ error message on initial startup. This is because DCAL workstations do not provide authentication capabilities to DCAL clients, therefore CAL clients do not prompt you for EMC user logon credentials.
Workaround #1:
Use the secure enterprise URL when configuring the CAL client rather than the DCAL workstation URL. The workstation automatically switches back to the DCAL workstation after the Simphony client has finished installing.
Workaround #2:
  1. Close the Simphony POS client on the workstation.
  2. Run the %AppRoot%\WebServer\AuthenticationServer.exe utility
  3. Confirm that the application server EGateway URL and Service Host ID are correct.
  4. Enter the EMC username and EMC password.
  5. Click the Authenticate button.
  6. Confirm that the ‘Authentication is successful’ message appears.
    Figure 6-3 Authentication for the DCAL Server
    This figure shows the authentication screen for a DCAL server.
