Sample JSON: Deliveroo
The following sample shows JSON code for Deliveroo. The tables that follow the code sample describe the values in the code.
Tip:
Click Copy to copy the code to your clipboard and then paste it into a text editor such as Notepad++. Change the values for your restaurant and then copy your code into the DeliveryPlatformConfigurationData column as described in Creating Delivery Configuration in the Revenue Center.
    "deliveryPlatformConfigurations": [
            "name": "Deliveroo",
            "groupIdentifier": "my-brand-gb",
            "rvcIdentifier": "my-brand-gb-531168",
            "empNum": 991,
            "otNum": 5,
            "remakeOtNum": 6,
            "tendNum": 13,
            "menus": [{
                    "name": {
                        "en-US": "All Day"
                    "identifier": "DeliverooAllDay",
                    "imageURL": "https://oracleobjectstore.com/images/deliveroo-all-day-menu.jpg",
                    "availability": null
        } // End of Deliveroo
Table 3-2 Data Extensions Column Name
Name Type Description
DeliveryPlatformConfiguration[]
Revenue center’s integration configuration for each applicable delivery platform.
Table 3-3 Delivery Platform Configuration
name
string
Deliveroo
Do not change this value.
groupIdentifier
string
Name of the grouping of restaurants by brand name and country. This value consists of the brand name and the country code.
rvcIdentifier
string
Identifier for the revenue center. This is the Site ID obtained during the registration process.
empNum
number
Object number for employee to be used to enter orders received from the delivery platform.
otNum
number
Object number for Order Type to be used for orders received from the delivery platform.
remakeOtNum
number
Object number for Order Type to be used for "remake" orders received from the delivery platform.
tendNum
number
Object number for Tender Media to be used to settle orders received from the delivery platform.
menus
DeliveryPlatformMenu[]
Details for menu(s) to be submitted to the delivery platform.
Make sure to follow any limitations imposed by the delivery platform on the number of menus.
Table 3-4 Delivery Platform Menu
name
TranslatedString
Display name for menu by locale.
identifier
string
Identifier for menu to be used in tags.
Make sure the identifier does not conflict with tags used for other purposes.
imageURL
string
URL for image associated with menu.
Upload the menu image to the Oracle Object Store through a dummy menu item.
availability
ServicePeriod[]
Start and end times for each day of the week that the menu is to be made available.
Table 3-5 Translated String
<locale code>
string
String translation for given locale.
Table 3-6 Service Period
dayOfWeek
string
First three letters of day of week for service period.
startTime
string
Start time for service period, in 24-hour (hh:mm) format.
endTime
string
End time for service period, in 24-hour (hh:mm) format.
End time must be later than start time.
