Sample JSON: Uber Eats
The following sample shows JSON code for Uber Eats. The tables that follow the code sample describe the values in the code.
Tip:
Click Copy to copy the code to your clipboard and then paste it into a text editor such as Notepad++. Change the values for your restaurant and then copy your code into the DeliveryPlatformConfigurationData column as described in Creating the Delivery Configuration in the Revenue Center.
    "deliveryPlatformConfigurations": [
            "name": "Uber Eats",
            "groupIdentifier": null,
            "rvcIdentifier": "984e0f54-64dc-15T3-e348-16942gs5arn5",
            "empNum": 990,
            "otNum": 4,
            "remakeOtNum": -1,
            "tendNum": 101,
            "menus": [{
                    "name": {
                        "en-US": "AllDayMenu"
                    "identifier": "UberEatsAllDayMenu",
                    "imageURL": null,
                    "availability": [{
                            "dayOfWeek": "Mon",
                            "startTime": "00:00",
                            "endTime": "23:00"
                            "dayOfWeek": "Tue",
                            "endTime": "23:00"
                            "dayOfWeek": "Wed",
                            "endTime": "23:00"
                            "dayOfWeek": "Thu",
                            "endTime": "23:00"
                            "dayOfWeek": "Fri",
                            "endTime": "23:00"
                            "dayOfWeek": "Sat",
                            "endTime": "23:00"
                            "dayOfWeek": "Sun",
                            "endTime": "23:00"
Table 2-2 Data Extensions Column Name
Name Type Description
DeliveryPlatformConfiguration[]
Revenue center’s integration configuration for each applicable delivery platform.
Table 2-3 Delivery Platform Configuration
name
string
Uber Eats
Do not change this value.
groupIdentifier
string
Set to null because the object does not apply to Uber Eats.
rvcIdentifier
string
Identifier for revenue center. This is the Site ID obtained during the registration process.
empNum
number
Object number for employee to be used to enter orders received from the delivery platform.
otNum
number
Object number for Order Type to be used for orders received from the delivery platform.
remakeOtNum
number
Set to -1 because the object is not valid for Uber Eats. Do not change this value.
tendNum
number
Object number for Tender Media to be used to settle orders received from the delivery platform.
menus
DeliveryPlatformMenu[]
Details for menu(s) to be submitted to the delivery platform.
Make sure to follow any limitations imposed by the delivery platform on the number of menus.
Table 2-4 Delivery Platform Menu
name
TranslatedString
Display name for menu, by locale.
identifier
string
Identifier for menu to be used in tags.
Ensure that the identifier will not conflict with tags used for other purposes.
imageURL
string
Uber Eats does not support a menu image. Set to null because the image URL does not apply to Uber Eats.
availability
ServicePeriod[]
Start and end times for each day of the week that the menu is to be made available.
Table 2-5 Translated String
<locale code>
string
String translation for given locale.
Table 2-6 Service Period
dayOfWeek
string
First three letters of day of week for service period.
startTime
string
Start time for service period, in 24-hour (hh:mm) format.
endTime
string
End time for service period, in 24-hour (hh:mm) format.
End time must be later than start time.
