Assigning Allergy Information for a Menu Item
When using Deliveroo, you have the option to include allergen information for a menu item on the delivery service provider application.
  1. Select the Enterprise, property, or revenue center, click Configuration, and then click Menu Item Maintenance.
  2. Search in the master records, and then select the menu item from the list.
  3. Click the General subtab.
  4. In the Allergen Class Override field, click Select, select the allergen class, and then click OK.
  5. Click Save.
