Configuring Customer-Facing Content
Specify the menu item name and description that customers see in the delivery provider application when placing an order.
  1. Select the Enterprise, property, or revenue center, click Configuration, and then click Menu Item Maintenance.
  2. Search in the master records, and then select the menu item from the list.
  3. Click the Images subtab.
  4. Enter or change the Consumer Item Name.
  5. Enter or change the Consumer Item Description.
  6. In the Image 1 section, click Upload to select the image and upload it to Simphony.
  7. (Optional) Enter or change the image Title.
  8. (Optional) Enter or change the image Comments.
  9. Enter null in the URL field.
    Uber Eats does not support a menu image.
  10. Click Save.
