Delivery Connector Configuration Deliveroo Configuring Menu Items Assigning a SLU Assigning a SLU Select the Enterprise, property, or revenue center, click Configuration, and then click Menu Item Maintenance. Search in the master records, and then double-click the menu item in the list. Click the General subtab. In the Touchscreen Properties section, select the relevant SLU from the drop-down lists in SLU through SLU 8. You can assign up to eight SLUs per menu item. Click Save. Parent topic: Configuring Menu Items
