Widgets
Widgets are tiles that you create to show on Simphony Engagement Cloud Service POS client screens. Widgets allow workstation operators to perform optional tasks and procedures based on the assigned privilege level.
You can assign timing values to three widgets. Timing values affect
the duration of time that widgets appear on an idle Engagement POS
client device screen. You can assign custom timing values to the following
widgets:
URL Launcher
Image Slideshow
Today’s Special
Engagement widget timing settings are overridden by Log Off User When Idle settings that are configured in the Simphony application, with the exception of the Web Configuration Console (WCC) widget. The WCC widget ignores the Simphony idle client timeout settings; the allowed idle time can be configured in MM:SS. The default timing value setting for the Engagement widgets is twenty seconds.
