21 Menu Item Classes
A menu item class consists of a set of options that apply to similar
menu items in a revenue center. A menu item class specifies information,
including:
The tax class associated with the menu items
The two types of menu items: Regular and Condiments
Active menu levels after ordering an item from the class
The order devices to which the items output
You can configure similar menu items into a class rather than individually
setting each menu item’s order device output or condiment settings.
For example, the menu items Cola, Diet Cola, and Root Beer all share
the following characteristics:
Receive the same tax rates
Do not require condiments
Output to the same order device
Therefore, you can create one menu item class called Soda and make all soda menu items a part of this class.
