Example of a Pre-Production Chit
Pre-Production chits are formatted differently than conventional order output to remote printers. The text * TO BE PREPARED * prints by default on each chit (with the Order Type showing directly beneath it), prior to the Dining Course name (if enabled), and then the quantity ordered is printed adjacent to each ordered Menu Item.
If enabled, the Dining Course Name prints and also adheres to the Print Classes settings, whereby if the 4 - On = Red, Off = Black option is enabled, the Dining Course name prints in red, and prints in black if disabled.
Here is an example of a Pre-Production Chit:
Figure 43-3 Example of a Pre-Production Chit
