DIP Switch Definitions
TM-U200A
  1. RS-232 serial interface model
    Table 40-57 DIP Switch 1
    Switch No. Function ON OFF Default Settings
    1
    Data reception error
    Ignored
    Prints “?”
    Off
    2
    Receive buffer capacity
    40 bytes
    ANK model: 1000 bytes
    Multilingual model: 512 bytes
    Off
    3
    Handshaking
    XON/XOFF
    DTR/DSR
    Off
    4
    Word length
    7 bit
    8 bit
    Off
    5
    Parity check
    Yes
    No
    Off
    6
    Parity selection
    Even
    Odd
    Off
    7
    Baud rate selection
    4800 bps
    9600 bps
    Off
    8
    BUSY condition
    Receive buffer-full
    Off-line
    Receive buffer-full
    Off
    Table 40-58 DIP Switch 2
    1
    Selects number of characters per line (cpl) 7x9 font / 9x9 font
    42 cpl / 35 cpl
    40 cpl / 33 cpl
    Off
    2
    For internal use only (*1) (Autocutter)
    Enabled
    Disabled
    On
    3
    Asynchronous
    Synchronous with clock
    Off
    4
    Undefined
    Off
    5
    For internal use only (*1) (Semi-autoloading)
    For type A
    For type B/D
    On
    6
    For internal use only (*1) (Flash memory rewriting)
    Enabled
    Disabled
    Off
    7
    Pin 6 reset signal
    Used
    Not used
    Off
    8
    Pin 25 reset signal
    Used
    Not used
    Off
  2. Parallel interface model
    Table 40-59 DIP Switch 1
    1
    Auto line feed
    Enabled
    Disabled
    Off
    2
    Receive buffer
    40 bytes
    Off
    3–7
    Undefined
    Off
    8
    Busy condition
    Receive buffer-full
    Off-line
    Receive buffer-full
    Off
    Table 40-60 DIP Switch 2
    1
    42 cpl / 35 cpl
    40 cpl / 33 cpl
    Off
    2
    Enabled
    Disabled
    On
    3
    For internal use only (*1) (Interface synchronization)
    Asynchronous
    Off
    4
    Undefined
    Off
    5
    For internal use only (*1) (semi-autoloading)
    For Type A
    For type B/D
    On
    6
    Enabled
    Disabled
    Off
    7
    Undefined
    Off
    8
    Pin 31 reset signal
    Used
    Not Used
    On
TM-U200B/D
    Table 40-61 DIP Switch 1
    Switch No. Function ON OFF Default B Default D
    1
    Ignored
    Prints “?”
    Off
    Off
    2
    40 bytes
    Off
    Off
    3
    Handshaking
    XON/XOFF
    DTR/DSR
    Off
    Off
    4
    Word length
    7 bit
    8 bit
    Off
    Off
    5
    Parity check
    Yes
    No
    Off
    Off
    6
    Parity selection
    Even
    Odd
    Off
    Off
    7
    Baud rate selection
    4800 bps
    9600 bps
    Off
    Off
    8
    BUSY condition
    Receive buffer-full
    Off-line
    Receive buffer-full
    Off
    Off
    Table 40-62 DIP Switch 2
    1
    42 cpl / 35 cpl
    40 cpl / 33 cpl
    Off
    Off
    2
    Enabled
    Disabled
    On
    Off
    3
    Pin 6 reset signal
    Used
    Not used
    Off
    Off
    4
    Pin 25 reset signal
    Used
    Not used
    Off
    Off
    5
    For type A
    For type B/D
    Off
    Off
    6
    Enabled
    Disabled
    Off
    Off
    7
    Asynchronous
    Off
    Off
    8
    Undefined
    Off
    Off
    *1: Do not change the settings of DIP switches 2–2, 2–5, 2–6, and 2–7.
    Table 40-63 DIP Switch 1
    1
    Auto line feed
    Enabled
    Disabled
    Off
    Off
    2
    Receive buffer
    40 bytes
    ANK Model: 1000 bytes
    Multilingual mode: 512 bytes
    Off
    Off
    3–7
    Undefined
    Off
    Off
    8
    Busy condition
    Receive buffer-full
    Off-line
    Receive buffer-full
    Off
    Off
    Table 40-64 DIP Switch 2
    1
    Selects number of characters per line (cpl) 7 x 9 / 9 x 9 font
    42 cpl / 35 cpl
    40 cpl / 33 cpl
    Off
    Off
    2
    Enabled
    Disabled
    On
    Off
    3
    Undefined
    Off
    Off
    4
    Pin 31 reset signal
    Used
    Not used
    On
    On
    5
    For type A
    For type B/D
    Off
    Off
    6
    Enabled
    Disabled
    Off
    Off
    7
    Asynchronous
    Off
    Off
    8
    Undefined
    Off
    Off
TM-U220A/B/D (STD)
  1. Serial interface model
    Table 40-65 DIP Switch 1
    Switch No. Function ON OFF Default A Default B Default D
    1
    Ignored
    Print “?”
    Off
    Off
    Off
    2
    40 bytes
    4 KB
    Off
    Off
    Off
    3
    Handshaking
    XON/XOFF
    DTR/DSR
    Off
    Off
    Off
    4
    Word length
    7 bits
    8 bits
    Off
    Off
    Off
    5
    Parity check
    Yes
    No
    Off
    Off
    Off
    6
    Parity selection
    Even
    Odd
    Off
    Off
    Off
    7
    Transmission speed selection
    4800 bps
    9600 bps
    Off
    Off
    Off
    8
    BUSY condition
    Receive buffer-full
    Offline
    Receive buffer-full
    Off
    Off
    Off
    Table 40-66 DIP Switch 2
    1
    Selects number of characters per line (cpl) (*)
    42 cpl / 35 cpl
    40 cpl / 33 cpl
    Off
    Off
    Off
    2
    Reserved (Autocutter)
    Enabled
    Disabled
    On
    On
    Off
    3
    Undefined
    Off
    Off
    Off
    4
    Serial communication set selection
    By memory switch
    By DIP switch
    Off
    Off
    Off
    5
    Undefined
    Off
    Off
    Off
    6
    Reserved (Flash memory rewriting)
    Enabled
    Disabled
    Off
    Off
    Off
    7
    Pin 6 reset signal
    Used
    Not used
    Off
    Off
    Off
    8
    Pin 25 reset signal
    Used
    Not used
    Off
    Off
    Off
    (*) Selection of dots between characters: On = 2 half dots, Off = 3 half dots
    The number of characters per line in the Table indicates for the 76 mm-width paper.
    Table 40-67 DIP Switch 1
    1
    Auto line feed
    Enabled
    Disabled
    Off
    Off
    Off
    2
    Receive buffer
    40 bytes
    4KB
    Off
    Off
    Off
    3
    Undefined
    Off
    Off
    Off
    4
    Undefined
    Off
    Off
    Off
    5
    Undefined
    Off
    Off
    Off
    6
    Undefined
    Off
    Off
    Off
    7
    Undefined
    Off
    Off
    Off
    8
    BUSY condition
    Receive buffer-full
    Offline
    Receive buffer-full
    Off
    Off
    Off
    Table 40-68 DIP Switch 2
    1
    42 cpl / 35 cpl
    40 cpl / 33 cpl
    Off
    Off
    Off
    2
    Enabled
    Disabled
    On
    On
    Off
    3
    Undefined
    Off
    Off
    Off
    4
    Undefined
    Off
    Off
    Off
    5
    Undefined
    Off
    Off
    Off
    6
    Enabled
    Disabled
    Off
    Off
    Off
    7
    Undefined
    Off
    Off
    Off
    8
    Pin 31 reset signal
    Used
    Not used
    On
    On
    On
    (*) Selection of dots between characters: On = 2 half dots, Off = 3 half dots.
TM-U220B/D (US STD)
    Table 40-69 DIP Switch 1
    1
    Printing mode
    Right side up printing mode
    Normal printing mode
    Off
    Off
    2
    40 bytes
    4KB
    Off
    Off
    3
    Handshaking
    XON/XOFF
    DTR/DSR
    Off
    Off
    4
    Word length
    7 bits
    8 bits
    Off
    Off
    5
    Parity check
    Yes
    No
    Off
    Off
    6
    Parity selection
    Even
    Odd
    Off
    Off
    7
    4800 bps
    9600 bps
    Off
    Off
    8
    BUSY condition
    Receive buffer-full
    Offline
    Receive buffer-full
    Off
    Off
    Table 40-70 DIP Switch 2
    1
    42 cpl / 35 cpl
    40 cpl / 33 cpl
    Off
    Off
    2
    Enabled
    Disabled
    On
    Off
    3
    Pin 6 reset signal
    Used
    Not used
    Off
    Off
    4
    Pin 25 reset signal
    Used
    Not used
    Off
    Off
    5
    Undefined
    Off
    Off
    6
    Enabled
    Disabled
    Off
    Off
    7
    Undefined
    Off
    Off
    8
    By memory switch
    By DIP switch
    Off
    Off
    Table 40-71 DIP Switch 1
    1
    Printing mode
    Off
    Off
    2
    Receive buffer
    40 bytes
    4KB
    Off
    Off
    3
    Undefined
    Off
    Off
    4
    Undefined
    Off
    Off
    5
    Undefined
    Off
    Off
    6
    Undefined
    Off
    Off
    7
    Undefined
    Off
    Off
    8
    BUSY condition
    Receive buffer-full
    Offline
    Receive buffer-full
    Off
    Off
    Table 40-72 DIP Switch 2
    1
    42 cpl / 35 cpl
    40 cpl / 33 cpl
    Off
    Off
    2
    Enabled
    Disabled
    On
    Off
    3
    Undefined
    Off
    Off
    4
    Pin 31 reset signal
    Used
    Not used
    On
    On
    5
    Undefined
    Off
    Off
    6
    Enabled
    Disabled
    Off
    Off
    7
    Undefined
    Off
    Off
    8
    Undefined
    Off
    Off
TM-T88III/IV/V and TM-T70
  1. Serial interface specification
    Table 40-73 DIP Switch 1
    SW 1 Function ON OFF Factory Setting
    1
    Ignored
    Prints “?”
    OFF
    2
    45 bytes
    4 KB
    OFF
    3
    Handshaking
    XON/XOFF
    DTR/DSR
    OFF
    4
    Word length
    7 bits
    8 bits
    OFF
    5
    Parity check
    Yes
    No
    OFF
    6
    Selection of parity
    Even
    Odd
    OFF
    7
    Selection of transmission speed
    See Table 18
    See Table 18
    ON
    8
    See Table 18
    See Table 18
    OFF
    Table 40-74 Transmission Speed
    Transmission speed (bps) SW 1–7 SW 1–8
    (*1)
    ON
    ON
    4800
    OFF
    ON
    9600
    ON
    OFF
    19200
    OFF
    OFF
    bps: bits per second
    Table 40-75 DIP Switch 2
    SW 2 Function ON OFF Factory Setting
    1
    Handshaking (Condition or BUSY)
    Receive buffer full
    Offline
    Receive buffer-full
    OFF
    2
    Reserved (Do not change settings)
    Fixed to OFF
    Fixed to OFF
    OFF
    3
    Selects print density
    See Table 20
    See Table 20
    OFF
    4
    See Table 20
    See Table 20
    OFF
    5
    Setting the conditions that cancel the receive buffer BUSY state (This function is effective when the receive buffer capacity is set to 4 KB.)
    Cancels the BUSY state when the remaining capacity of the receive buffer reaches 138 bytes.
    Cancels the BUSY state when the remaining capacity of the receive buffer reaches 256 bytes.
    OFF
    6
    Fixed to OFF
    Fixed to OFF
    OFF
    7
    I/F pin 6 reset signal
    Enabled
    Disabled
    OFF
    8
    I/F pin 25 reset signal
    Enabled
    Disabled
    OFF
    Table 40-76 DIP Switch 2–3 and 2–4
    Switch No. 3 Switch No. 4 Function
    OFF
    OFF
    Print density (Standard)
    ON
    OFF
    Print density (Medium)
    OFF
    ON
    Print density (Dark)
    ON
    ON
    Prohibited
  2. Parallel interface specification
    Table 40-77 DIP Switch 1
    SW Function ON OFF Factory Setting
    1
    Auto line feed
    Always enabled
    Always disabled
    OFF
    2
    45 bytes
    4 KB
    OFF
    3
    Selects paper sensors to output paper-end signals (default value of ESC c 3)
    Disabled
    Roll paper end sensor enabled; roll paper near-end sensor enabled
    OFF
    4
    Sets error signal
    Disabled
    Enabled
    OFF
    5–8
    Undefined
    OFF
    Table 40-78 DIP Switch 2
    1
    Handshaking (Condition for BUSY)
    Receive buffer full
    Offline
    Receive buffer full
    OFF
    2
    Fixed to OFF
    Fixed to OFF
    OFF
    3
    See Table 23
    See Table 23
    OFF
    4
    See Table 23
    See Table 23
    OFF
    5
    Setting the conditions that cancel the receive buffer BUSY state (this function is effective when the capacity of the receive buffer is set to 4 KB).
    OFF
    6
    Fixed to OFF
    Fixed to OFF
    OFF
    7
    Fixed to OFF
    Fixed to OFF
    OFF
    8
    Interface pin 31 reset signal (Do not change settings)
    Fixed to ON
    Fixed to ON
    ON
    Table 40-79 DIP Switch 2–3 and 2–4
    3 4 Function
    OFF
    OFF
    ON
    OFF
    OFF
    ON
    ON
    ON
    Prohibited
TM-T70II
Table 40-80 Memory Switch 1
Memory Switch Function Setting Value — 48 (OFF) Setting Value — 49 (ON) Defaults
1–1
(Reserved)
48 (OFF)
1–2
4 KB
45 bytes
48 (OFF)
1–3
Condition for BUSY
Receive buffer full or offline
Receive buffer full
48 (OFF)
1–4
Data processing for receiving error
Replaced with “?”
Ignored
48 (OFF)
1–5
Automatic line feed
Always disabled
Always enabled
48 (OFF)
1–6
(Reserved)
48 (OFF)
1–7
(Reserved)
48 (OFF)
1–8
(Reserved)
48 (OFF)
Table 40-81 Memory Switch 2
2–1 to 2–8
(Reserved)
48 (OFF)
Table 40-82 Memory Switch 3
3–1 to 3–8
(Reserved)
48 (OFF)
Table 40-83 Memory Switch 4
4–1 to 4–8
(Reserved)
48 (OFF)
Table 40-84 Memory Switch 5
5–1
Sets USB power-saving function *1
Enabled
Disabled
48 (OFF)
5–2
Sets recovery conditions from receive buffer BUSY (Enabled when the receive buffer capacity is set to 4 KB)
Recovers when the remaining receive buffer capacity becomes 256 bytes
Recovers when the remaining receive buffer capacity becomes 138 bytes
48 (OFF)
5–3
Disabled
48 (OFF)
5–4
Sets error signal
Enabled
Disabled
48 (OFF)
5–5
(Reserved)
48 (OFF)
5–6
(Reserved)
48 (OFF)
5–7
(Reserved)
48 (OFF)
5–8
(Reserved)
48 (OFF)
*1: Valid only when the USB interface communication condition is set to the vendor-defined class and the system configuration is set so that the USB driver can support the USB power-saving function.
Function 11
This figure shows the function 11 details.
Function 11 — Descriptions
  • Sets the configuration item for the serial interface specified by a to the values specified by d.
a Configuration Item
1
Transmission speed
2
Parity
3
Handshaking
4
Bit length
  • Transmission speed settings (a = 1)
d1...dk Transmission Speed
“2400”
2400 bps
“4800”
4800 bps
“9600”
9600 bps
“19200”
19200 bps
“38400”
38400 bps
“57600”
57600 bps
“115200”
115200 bps
  • Parity settings (a =2)
d1 Parity
48
None
49
Odd
50
Even
  • Handshaking settings (a = 3)
d1 Handshaking
48
DTR/DSR control
49
XON/XOFF control
  • Bit length settings (a = 4)
d1 Bit Length
55
7 bits
56
8 bits
