Slip Printer
A slip printer does not contain paper. The workstation operator must add a piece (or slip) of paper per print job. Properties who use custom stationery (often containing a company logo or other similar artwork) generally use slip printers for guest checks and customer receipts. Slip printers are also used for check endorsement printing. The slips that are used by these printers are often called hard checks because they are usually made of card stock.
Slip printers are not supported when using Transaction Services Gen 1 and Simphony Transaction Services (STS) Gen 2.
