Table Management Alerts
You can set two optional types of table management alerts: Service Alerts and Check Alerts.
Service Alerts show the duration since the last service interaction (for example, guest ordered a menu item). If you do not set Service Alerts, the table management system does not track service intervals on the guest check.
Check Alerts show how long the guest has been seated at the table. This alert changes as the service interaction passes defined thresholds. If you do not set Check Alerts, the table management system only tracks the duration of time the guest check is open and does not change the Check Alert color.
Related Topics
Parent topic: Dining Room Tables and Seating
