Combo Meal Function Keys
Workstation operators can use the following function keys (if configured) with combo meals:
Table 32-7 Combo Meal Function Keys
| Function Key | Description |
Auto Combo |
This key allows the workstation operator to create one or more combo meals from existing menu items. |
Combo |
This key changes the selected item or the last item on the check to a combo meal. The item must be a primary combo item. For example, if the combo meal is a burger with fries and a drink, the burger item must be the highlighted item or the last item ordered before pressing this key. |
Combo Alternate Side |
This key allows the workstation operator to substitute a combo meal side with a selection from another combo meal group (for example, when a customer orders an appetizer instead of an entree in a combo meal). |
Combo Bulk Order |
This key allows the workstation operator to order multiple combo meals at a time. The workstation operator must meet each combo’s side item requirements before moving on to order the next combo’s side items. |
Combo Multi Selection |
This key allows the workstation operator to select existing menu items to combine into a combo meal. This function shows the check detail in a window, which allows the workstation operator to select individual items to make up the combo meal. This gives the workstation operator greater control in determining what is included in the combo meal. |
Un-Combo |
This key separates an existing combo meal into individual à la carte items (non-combo pricing takes effect). |
Type - Combo Order Size |
This key changes the order size before ordering the combo meal. |
Type - Combo Size 1-4 |
These keys change the combo size after ordering the combo meal. Using these keys causes the workstation to resize the selected combo meal or combo meal side item to selected sizes 1 through 4. If the workstation operator does not select an item, the last item on the check is resized. |
