Configuring the Show Database Provider Button
The following steps are optional:
- Select the Enterprise, property, revenue center, or zone, click Configuration, and then click Page Design.
- Double-click the page on which you want the Show Database Provider button to appear (typically the Sign In page).
- Insert a new button.
- On the General tab, select Function from the Type drop-down list, and then click the right arrow beneath the Type field.
- On the left pane, in the Name field, enter Show Database Provider.
- On the right pane, select Show Database Provider as the result, and then click OK.
- Click Generate Legend to set Show Database Provider as the button name.
- Click Save.
Parent topic: Optional CAPS Configuration Tasks
