Verifying CAPS Installation
The following steps are optional:
  1. Log in as the CAPS user on the Oracle database to verify the tables.
  2. Verify the log files on the CAPS EGateway log and the workstation EGateway log folders.
  3. Configure a new POS client workstation that points to CAPS from the Property Parameters module (Workstations tab).
    See Adding a Workstation for more information.
  4. Click the Show Database Provider button, and then verify that CAPS DB: as Oracle appears.
  5. Verify that the CAPS status is online.
  6. Add a few test transactions from the workstation.
  7. Verify that the transaction details post to the CHECKS table on the workstation datastore database, the CAPS database, and the Simphony transaction database.
