Allowing Employees to Edit Guest Check ID on Open Check
  1. Select the Enterprise level, click Configuration, and then click Roles.
  2. Double-click the role type, click the Operations tab, and then click the Guest Checks subtab.
  3. To set permission to edit the check ID, select 81 - Authorize/Perform Edit of Guest Check ID In an Open Check.
  4. Click Save.
