Select the Enterprise level, click Configuration, and then click Roles.
Double-click the role type record (for example, administrator,
manager or server).
Click the Operations tab, and then
click the Guest Checks subtab.
Select the appropriate permission options for the user
role:
45 - Authorize Transfer of Checks in the Same Revenue
Center: Select to allow employees with this role to transfer
checks from another operator within the same revenue center, and to
authorize others to do so.
46 - Authorize Transfer of Checks Between Revenue
Centers: Select to allow employees with this role to transfer
checks from another revenue center, and to authorize others to do
so.
47 - Authorize Adding of Checks in the Same Revenue
Center: Select to allow employees with this role to add
checks (to be in a check, and add another check to it) within a revenue
center, and to authorize others to do so.
48 - Authorize Adding of Checks Between Revenue
Centers: Select to allow employees with this role to add
checks (to be in a check, and add another check to it) from another
revenue center, and to authorize others to do so.
