Select the revenue center, click Setup, and then click RVC Parameters.
Click the Options tab, and then select 68 - Enable Follow Me.
When you set Follow Me, option 60 - Enable Suspend/Resume dims, and vice versa. You cannot select both Follow Me and Suspend/Resume; they are mutually exclusive. When you set Follow Me, each workstation in the revenue center participates in the Follow Me operation.
Select the property, click Setup, and then click Workstations.
On the General tab, enter information in the fields as described in the following table:
Table 33-4 Workstation Timeout Settings
Timeout Setting
Description
Check Inactivity Timeout
Enter the number of seconds that the workstation waits before prompting the workstation operator to cancel a transaction. If you set this value to 0 (zero), the Cancel dialog does not appear.
If you select 68 - Enable Follow Me from the RVC Parameters module, the guest check is automatically suspended rather than cancelled.
Check Inactivity Dialog Timeout
Enter the number of seconds that the workstation shows the Do you need more time? Inactivity dialog before automatically cancelling the transaction. If you set this value to 0 (zero), the Cancel dialog does not appear.
