Configuring Pickup Next Check by Service Total Time
You can configure a function key to pick up the next check by service total time. This function allows a workstation operator to pick up the next check based on the service total time, and is typically used in a drive-through environment.
  1. Select the Enterprise, property, revenue center, or zone, click Configuration, and then click Page Design.
  2. Double-click the transaction page on which you want the pickup next check by service total time function key to appear on the workstation.
  3. On the Edit tab, select the page area in which to define the Pickup Next Check by Service Total Time key.
  4. Click Button.
  5. On the General subtab, enter the button name in the Legend field (for example, Pickup Next Check by Service Total Time).
  6. Select Function from the Type drop-down list.
  7. Click the black arrow directly beneath the Type drop-down list.
  8. Enter pick in the Name field, select Pickup Next Check by Service Total Time in the Results list, and then click OK.
  9. Position and size the button on the page. Use the Style arrow to change the color.
  10. Click Save.
