Configuring Send and Stay
Follow these instructions to configure the Service Total to send items to be prepared while the check remains open.
- Select the property, click Configuration, and then click Tender/Media.
- Insert a Service Total record if it does not exist.
- Double-click the record to open it.
- On the General tab, select 2 - Service Total from the Key Type drop-down list.
- Click the Options tab, and then click the Ops Behavior subtab.
- Select 95 - Send Order.
- Click Save.
- Add a touchscreen button for the tender/media record that you created in Step 2. Adding a Service Total Key to the Transaction Page contains more information about configuring a service total touchscreen button.
Related Topics
- Adding a Service Total Key to the Transaction Page
- Setting the Hold and Fire Option
- Setting the Hold and Fire Tender Notification
- Setting a Reminder for Items on Hold
- Configuring Checks with Items on Hold to End Current Service Round
- Configuring Check Handling For Closing Checks With Held Items
- Configuring Item Hold Buttons
- Order Handling on Open Checks
- Holding and Sending Items to Order Devices
Parent topic: Guest Checks
