Select the revenue center, click Setup, and then click RVC Parameters.
Click the Options tab, and then
select 60 - Enable Suspend/Resume.
Click Save.
Select the Enterprise, property, or zone, click Configuration, and then click Tender/Media.
Insert a record with the tender name.
Double-click the tender record.
On the General tab, select 2 - Service Total from the Key Type drop-down list.
click the Ops Behavior subtab.
Select 74 - Suspend Order.
Click Save.
Select the Enterprise, property, revenue center, or zone,
click Setup, and then click Tender
Parameters.
Click the Configuration tab.
To configure a default Suspend Order tender, in the Default Suspend Order Tender drop-down list, select the
suspend order tender.
A default Suspend Order tender is needed for certain suspend
scenarios, such as when a workstation operator is auto-signed out
or when another operator signs in.
