Creating Menu Item Master Records for Condiments
  1. Select the Enterprise, property, revenue center, or zone, click Configuration, and then click Menu Item Maintenance.
  2. Insert a new record, and then enter the condiment name (for example, Ham).
  3. Search for and then double-click the new record
  4. Insert a definition record, and then click the General subtab.
  5. From the Name and Class section, select the Menu Item Class for the condiment.
  6. To set a priced condiment:
    1. Click the Prices subtab, insert a price definition, and then enter the Price for the condiment.
    2. To set the price to become active at a specific menu level, select Active On Level, and then select the level.
  7. Click Save.
  8. Repeat Steps 2 through 6 to create menu item master records for all condiments.
