Configuring a Popup Condiment Orderer Page
  1. Select the Enterprise, property, revenue center, or zone, click Configuration, and then click Page Design.
  2. Insert a record for Popup Condiment Orderer if it does not exist.
  3. Double-click the record to open it.
  4. Select Specify Template, and then select Popup Condiment Orderer from the Internal Templates list.
    The template is preset with a Condiment Orderer control and a Done button. You cannot delete these elements from the template, nor can you copy elements to this template. The Popup Condiment Orderer template supports two key functions: Void and Transaction Cancel.
  5. From the Popup Type drop-down list, select the location for the Popup Condiment Orderer on the page. (The Popup Types do not apply to POS clients running the Android mobile operating system.)
    • Full Screen
    • Centered
    • Next to Check Detail Area
    • In Dynamic Content Area
  6. Select Allow selection in check detail area to allow workstation operators to select the current menu item and its condiments in the check detail area while the Popup Condiment Orderer is open.
  7. Select Manually dismiss Condiment Orderer to have the Popup Condiment Orderer remain open after the workstation operator selects all required condiments. The workstation operator must use the Done button to close the Popup Condiment Orderer.
    If you configure required condiment groups with a zero minimum count, select Manually dismiss Condiment Orderer. Otherwise the Popup Condiment Orderer automatically closes because the application meets the minimum required count (zero) before the workstation operator orders a condiment in the group.
  8. (Optional) Change the page settings, such as layout and button styles. You cannot modify the dimmed settings.
  9. (Optional) Repeat Steps 2 through 8 to create additional Popup Condiment Orderer pages. The POS client requires one page for initial condiment selection and subsequent editing, although you can configure two pages.
    When you designate Next Page/Panel for menu items (in menu item classes and on menu item buttons), the POS client goes to the designated page or panel after the Popup Condiment Orderer closes (either manually or automatically).
  10. Click Save.
Related Topics
