- Configuration Guide
- Engagement Cloud Service
- Adding an Employee From a Template
- Sign on to the POS client device, and then tap the Hub function.
- Tap the tile configured for the Copy Employee manager procedure.
- Tap Filter Employees, select the revenue center, the employee role, and the employee class to assign to the new employee.
- Select an employee from the search results, and then tap Copy Employee.
- Configure the following information for the new employee:
Table 53-2 Configuration Fields for Adding New Employees From a Template
Field or Option Name Description First Name
Enter the employee’s first name.
Last Name
Enter the employee’s last name.
DOB
Select the employee’s date of birth.
Hire Date
Enter the date the employee was hired.
(Optional) MagCard ID
Enter the magnetic card number assigned to the employee or swipe the card to enter the card number into the application.
(Optional) Finger Print
If a fingerprint scanner is connected, you can scan the employee’s fingerprints into the application.
RVCs
Select the employee’s revenue center.
You cannot change the primary revenue center of the employee.
Enable Reporting
Select this option to grant the employee access to Oracle Hospitality Reporting and Analytics.
Is Salaried
Select this option if the employee is paid a flat amount.
Pay Rate
Enter the employee’s pay rate.
Logon Name
Enter the username to use to sign on to the workstation.
If you selected Enable Reporting, the employee can use the same username to sign on to Reporting and Analytics.
Password
Enter the password to use to sign on to the workstation.
Confirm Password
Re-enter the password.
- To add an image to the employee’s profile:
- Tap Change Picture, and then tap Browse Image.
- Select the employee’s image, and then tap Open.
- Tap Add Employee, and then tap Yes to confirm the insertion.
Related Topics
- Adding Engagement Manager Procedure Tiles to the Hub Page
- Editing the Check Header and Trailer
- Editing Bulk Menu Item Prices
- Deactivating an Employee
- Adding a New Menu Item Using an Existing Menu Item as a Template
- Adding Images to Menu Items
- Adding or Changing an Employee’s Profile Image
- Engagement Manager Procedures
Parent topic: Engagement Cloud Service
