Modifying Pages for Engagement Users
You can modify pages using the controls that appear when you select a page.
- To make changes to a page, select the page, and then tap Edit.
- To duplicate a page, select the page, and then tap Clone.
- To remove a page, select the page, tap Delete, and then tap OK to confirm.
