Click the Options tab, and then
click the Interface Options subtab.
In the View Interface Names for RVC drop-down list, select the revenue center for which the OPERA PMS
interface was assigned, and then select PMS from the Interface Link drop-down list.
The Interface Link and the View Interface Names for RVC fields are only active if
the Tender/Media configuration is being performed at the property
level.
Assign the PMS Interface Link to
all payments that must be auto balanced (for example, Cash, Credit
Cards, and so on).
Select the following options:
29 - ON=Post 0.00 Transactions to PMS; OFF=Do Not
Post
31 - ON=PMS and Credit Cards Use 19 Digit Acct Number;
OFF=16 Digits
38 - Use ISL TMED Procedure Instead of PMS Interface
Figure 57-15 Tender/Media Room Charge Options
Click the Ops Behavior subtab and
in the General Options section, ensure that 5 - Reference
Entry Required is not enabled.
Click the Data Extensions tab, and
then select the check box in the Value column
for the Enh.IFC – Room Charge.
The Value check-box must be selected
for the room charge tender media(s). Deselect the check-box for all
other tender medias.
Figure 57-16 Tender/Media Room Charge Data Extensions Tab
