- Configuration Guide
- Guest Checks
- Configuring Employee Privileges for Automatic Check Firing
- Select the Enterprise level, click Configuration, and then click Roles.
- Double-click an employee role, click the Operations tab, and then click the Guest Checks subtab.
- Select the appropriate privileges. The following table
describes the privileges corresponding to automatic check firing.
Table 33-2 Employee Guest Check Privileges for Automatic Check Firing
Privilege Description 183 - Begin Autofire Check using [Begin Autofire Check] Key
Select this option to allow employees in this role to create checks with orders that automatically fire at a preset time using the Begin Autofire Check function key.
184 - Authorize/Perform Pickup of Autofire Check Belonging to Another Operator
Select this option to allow employees in this role to pick up and edit checks with orders that fire at a preset time from other employees.
185 - Authorize/Perform Edit of Autofire Date/Time
Select this option to allow employees in this role to modify the date and time that orders are set to automatically fire.
- To allow employees in this role to generate the Autofire Open Check Report from the workstation, click the Ad Hoc Reports subtab, and then select 31030 - Run Autofire Open Check Report.
- Click Save.
Parent topic: Guest Checks
