Configuration Guide Importing and Exporting Data Increasing the Import File Size Increasing the Import File Size Complete these steps if the Enterprise requires you to import files larger than the default 4MB size. Browse to [Drive Letter]:\MICROS\Simphony2\SimphonyImportExport\WebApp\ and open the Web.config file. Add the following line within a comment: <httpRuntime targetFramework="4.5" /> Uncomment the following line: <httpRuntime targetFramework="4.5" executionTimeout="240" maxRequestLength="10243"/> Enter the maximum import file size for the maxRequestLength parameter in Kilobits. By default, this value is set to 10 MB. Save the changes. Related Topics Configuring the Import/Export Service Privileges Configuring the Import/Export Service Import/Export Service Components Parent topic: Importing and Exporting Data
