Adding Menu Item Definition Records to a Single Menu Item Master
Select the Enterprise, property, revenue center, or zone,
click Configuration, and then click Menu Item Maintenance.
Double-click a master record to open it.
Click the Insert icon on the toolbar.
From the Select a task to perform drop-down list, select Add Definition Records to this
Master.
The Master field shows the Menu Item Master to receive the
new definition records.
From the Definitions to Add list,
select the number of definitions to create for the master.
Up to 64 definitions can exist for one master record. Simphony
ignores requests to create definitions greater than sequence number
64.
If the master record already has definitions configured,
select an existing menu item definition to use as a template for the
new definition record from the Use Template drop-down list.
(Optional) To add price records when creating the definition:
Select Insert Price Records.
If you are not using a definition template, select the Number of Price Records to create for the definition,
and then enter the default Price for the new
price records.
If using a definition template, Simphony copies the price
records from the template record.
