Select the Enterprise, property, revenue center, or zone,
click Configuration, and then click Menu Level Sets.
The Type column specifies whether
the Menu Level Set refers to the Main Levels, the Sub Levels, or to
the levels defined within the record. Main Levels and Sub Levels are
not configured in this module. However, you can create an entry for
the entire Main Level Set and Sub Level Set in this module; this allows
you to configure the Options and Default Master Group fields for Main
and Sub levels.
To create a custom menu level, insert a new record, and
then enter a custom level set name.
To define main menu levels, double-click Main.
To define sub menu levels, double-click Sub.
To define menu levels for a custom level set, double-click
the new custom level that you created in Step 2.
Select the appropriate options:
To change the menu level to the default level when the
workstation operator presses a touchscreen button corresponding to
any menu level in this menu level set again, select 1 -
Pressing level key again reverts to default level.
If the menu level set is bound to a Default Master Group
and you want the POS client to switch the active parent menu item
when the active menu level changes, select 2 - Bound to
parent.
(Optional) Select the Default Master Group for the menu level set.
This field is used for conversational ordering. If a Default
Master Group is assigned, when a Menu Level in this group is pressed,
Simphony determines which item from the selected Menu Item Group (if
any) to apply to the check.
In the Menu Level Entries section, define the menu levels.
You can use Menu Levels to specify menu item sizes, such
as Small, Medium, and Large, and serving periods, such as Happy Hour.
(Optional) Enter the Prefix or Suffix for each menu level to show on the check detail
area and print on guest checks and customer receipts.
To define a menu level as the default level for the menu
level set:
In the Options column, click the ellipsis point (...)
button adjacent to the default menu level.
Select 1 - Default, and then
click OK.
To define a menu level as an anonymous level for the menu
level set:
button adjacent to the anonymous menu level.
Select 2 - Anonymous, and then
click OK.
The Default and Anonymous menu levels are generic, and are
typically used with $0.00 priced menu item definitions that have names
such as [SIZE] Hot Drink or [TEMP] Drink.
