Configuring Touchscreen Buttons for Order Types
  1. Select the Enterprise, property, revenue center, or zone, click Configuration, and then click Page Design.
  2. Open the page on which to place the order type buttons, and then on the Edit tab, select the page area in which to define the buttons.
  3. Click Button.
  4. To configure a menu item order type button:
    1. On the General subtab, select Menu Item Order Type from the Type drop-down list
    2. Click the black arrow directly beneath the Type drop-down list, select an order type from the list, and then click OK.
  5. To configure a transaction order type button:
    1. On the General subtab, select Transaction Order Type from the Type drop-down list
  6. To configure a check order type button:
    1. On the General subtab, select Order Type from the Type drop-down list
  7. Enter a Legend for the button, and then position and size the button on the page.
  8. Click Save.
  9. Repeat Steps 3 through 8 to configure more order type buttons.
