Select the Enterprise level, click Configuration, and then click PC Autosequence Schedules.
Insert a record for the autosequence schedule (for example, Nightly Batch). If the autosequence schedule record exists, skip this step.
Double-click the record to open it.
On the General tab, enter information in the following fields:
Table 12-12 General Settings Fields
Field
Description
Autosequence
Select the autosequence event from the drop-down list.
Server Name
Enter the name of the server located at the Enterprise level or Hosting Center.
Time Zone
Select the time zone of the Enterprise level or Hosting Center.
Schedule Type
Select the frequency for the autosequence event.
Duration
Select Enabled for the autosequence event to run.
Select the Start and End dates for the autosequence event.
Click the Recurrence tab.
From the Daily section, enter the number of days for the autosequence event to reoccur. For example, to run the event daily, set this value to Every 1 day(s).
From the Daily Frequency section, set the time or times for the autosequence event to run.
