Configuring the 1D/2D Imager Scanner
You can configure the 1D/2D Imager Scanner for use with the Oracle MICROS Workstation 6 Series and Oracle MICROS Compact Workstation 310.
  1. Select the property, click Setup, and then click Workstations.
  2. Double-click the workstation record to open it.
  3. Click the Devices tab.
  4. Click Add in the Peripheral Device Configuration section.
  5. From the Select Peripheral Device Type drop-down list, select Generic Barcode Reader.
  6. Under COM Port Settings, select the COM PORT.
    The default COM Port setting is COM14.
    To find the appropriate COM number, navigate to the workstation device manager and locate the COM number associated with the workstation.
  7. Click Save.
  8. After configuration in EMC, update the workstation.
  9. Following the update, shut down the workstation, and then connect the scanner.
    The workstation should always be turned off when connecting or disconnecting a scanner.
  10. Restart the workstation.
  11. Verify that the scanner is successfully initialized with the workstation.
